Old 03-28-2012, 06:21 AM   #11 (permalink)
whiskey_juliet
The vacuum gauge isn't a reliable source for judging throttle position. It would vary based on RPM, load and throttle position.
I agree that tapping into the TPS gauge isn't a plausible method either due to any discrepancies the ECU might read.
Most likely a stand alone system will be used. Using a potentiometer to tell throttle position and an LED bar or digital display to give a real time readout.
