As far as reliability goes they are at least on par with Civic. As far as the ratings go check out fueleconomy.gov and start putting different years in the side by side comparos and then check with your budget.
Ford Escorts were pretty good in the day as well.
Are you limited to gasoline engines? What are some of your other parameters of your search besides auto transmission?
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
