Old 03-28-2012, 04:59 PM   #4 (permalink)
mja1
truck - '06 Chevrolet Silverado WT
90 day: 22.65 mpg (US)
Vapor carb was a spinoff of Smokey Yunick's 'hot vapor' engine. he used a 4cyl pontiac 'iron duke' to roll out of spark and run the engine basically off preignition. He nearly doubled the gas mileage and hp of a the little fiero he worked on, while driving completely normally. Dude was a genius.
Problem with the 'vapor carb' is most carbed intake manifolds and runners (or wet manifolds in general) are not ported, to help with atomization of gas/air charge. By the time the charge enters the combustion chamber, temps will atomize the charge regardless. Unless combined with a system that can take advantage of the lower autoignition temperature of the vapor charge (like yunick's fiero), it really won't make that much difference.
