Old 03-28-2012, 08:33 PM   #10 (permalink)
oil pan 4
You think superheating gasoline will boost fuel milage by xxx% ?
If that worked than propane would be a real good test of this concept, since at room temperature propane is a superheated vapor.
The problem is BTUs per miles on carbed gas vs propane/natural gas engines is about the same.
There is no unexplainable wild FE jump by switching to a superheated fuel.
