Old 03-28-2012, 11:17 PM   #24 (permalink)
ecofreak
Originally Posted by RunningStrong View Post
I don't think the dam needs to extend to the full width of the tyres, otherwise it tends to throw out a wake that effectively increases the frontal area.
Anything to get air away from the tires is ideal. The increase in frontal area wouldn't factor in if it's also funneling air away from the sides of the car.
It's been said before, but the best aeromods would be the pan and a grille cover. Taping over some of the body creases and gaps might also help.
You'd be better off practicing some technique, even though that does eventually involve going to the pump.
