Old 03-29-2012, 02:28 AM   #16 (permalink)
JellyBeanDriver
JellyBeanDriver's Avatar
Ends up I'm going to make a bunch of these due to requests on GMF. Board is out being fab'd, should have it next week.
Pretty much the same board as shown in my posts above but with added traces to feed the 2 unused analog inputs on the ATMega for those that want to add other features. Also added in a 6 pin ICSP header for programming.
Only comes with the switches shown but I do have solder pads for adding external switches (you can cut the bats off the existing switches if you don't want to use them).
Will be assembled - I laid out the board for my ease of assembly and cost so I'm using SMT parts, some thru hole where the parts are cheaper.
Stay tuned (I don't frequent this page that often)
(oh, and I need to update my signature - my metro is up to 411,000 miles on the original engine).
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
