Old 03-29-2012, 02:17 PM   #15 (permalink)
Daox
As long as it isn't totally blocked and the radiator fan can turn on and suck air through you'll be fine. You just don't want the fan running much. Its pretty easy to just use a 12V bulb or something to see when the fan is on or not. From there you can adjust the grill block.
