Old 03-29-2012, 06:40 PM   #17 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by saphiro View Post
The front air-dam might be a little bit more difficult, I'll have to stomach my pride and drill into the chrome front bumper.
Don't drill in the bumper.
Can't you fit the airdam to the car by using what's keeping the bumper on, if need be with a metal bracket, rather than fit it to the bumper itself ?
Also, I have been adding ATF to the fuel at approx. 1 oz to every 2 gallons. My theory is that the detergents in the ATF have cleaned out (and are continuing to do so) the injection pump and injectors, allowing them to work properly/better.
Don't you have detergents in diesel ?
Well, here's hoping for 35 mpg!
Looks like you're well on the way.
In such an old diesel, I'd run biodiesel though.
The older the car, the more pollutants it pumps out per gallon.
With biodiesel, you can reduce that pollution again.
