Old 03-29-2012, 10:01 PM   #15 (permalink)
drmiller100
strangely enough, I invented M85, or at least the latest version of it and the process to do it.
Pretty easy.
Take 40 gallons of used motor oil or used ATF.
add 6 gallons of gasoline.
mix thoroughly.
filter through 5 micron filter, and run it in your truck.
we've got probably half million miles on ford 7.3's, a lot on dodge 12 valves, some dodge 24 valves.
not recommended for common rail or anything with a cat.
