Old 05-30-2008, 11:18 AM   #20 (permalink)
ebacherville
Veggiedynamics
Volt12 - '12 Chevy Volt base
Originally Posted by .Cd View Post
Instead of removing the hatch entirely, you could just modify the angle of it.
Just open the hatch to the desired angle and fill in the gaps around it.
This would allow you to use the stock hatch and hinge set up.
You could then just continue the tail beyond this point.
With the hatch at the needed angle you wont be able to see out the rear glass anyway.. no need to keep it there if its useless... ill retail the opening hatch it will just be re-angled to fit aerodynamics.
