Thread: No DFCO?
Old 03-30-2012, 12:16 PM   #7 (permalink)
Kodak
Kodak's Avatar
Canyon - '07 GMC Canyon 2wd regular cab
90 day: 24.95 mpg (US)
Originally Posted by AndrzejM View Post
Sometimes there is a switch on the throttle that signals closed throttle to ECU. Maybe yours is just malfunctioning? Check this, maybe that is causing the trouble.
Hmm. For what it's worth, zero throttle input usually reads a throttle position of ~18. It varies a bit from 17 to 18. I've read that this is normal, and it's been that way since I've had the gauge.
Originally Posted by jakobnev View Post
I assume your engine was fully warmed up when you tested this?
Yes. Normal operating temperature, so I'm sure it was in closed loop.
EcoDriving: Turning more fuel into usable forward motion.
