I agree there probably are some gains to be made, possibly quite large, but that needs to be determined. I suppose the point I'm trying to make is the cost/benefit/risk analysis needs serious attention. Is the benefit large enough to warrant the risk, with the risk being a blown motor if the system is not engineered appropriately.
A lot of 4x4 guys often have an electric pump in addition to the mechanical ones to cover more extreme situations, and through a lot of my research with performance mods, once more power is brought on then upgrades in the cooling system are required, which leads me to believe the cooling system may not be as oversized as many think.
So I suppose the question is: How much is the pump oversized for the job required?
