Old 03-31-2012, 10:55 AM   #48 (permalink)
oil pan 4
Originally Posted by Tesla View Post
how do you know if you are circulating the coolant fast enough?
Coolant the engine is discharging vs. radiator outlet temperature.
Originally Posted by autoteach View Post
for $200 you can buy a pwm to control the speed. I would not use a resistor.
A resistor is a lot less than $200 and cant burn out.
If you spend $200 plus the cost of the pump which is in the $160 to $500 range the part about the mod being economical is long gone.
I am sticking with resistors.
Originally Posted by mechman600 View Post
The thermostat is two valves: rad closed/open and bypass open/closed.
Smaller engines don't have this, its called a bypass blocking thermostat. Smaller vehicles have a bypass that flows all the time and a thermostat that opens when the coolant gets hot. When the thermostat is open the bypass coolant is still going.
Even on vehicles with a bypass blocking thermostat they still have another bypass.
