Old 03-31-2012, 02:49 PM   #4 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
If your bearing are worn out enough that they are burning up the oil that should lube them, then yes, it's way past the time to replace them, I would imagine that you will see an improvement, if you try to push the car by hand right now I'm sure you will feel the drag, just like if you had brake drag.
