Old 03-31-2012, 09:21 PM   #11 (permalink)
bobo333
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
thanks for the info guys,
i have a 73hp 1.3L and as you said MetroMPG the radiator is offset to the left, i have found a shop nearby that sells a temperature sensor kit that has a digital readout and also can be set up to switch things on or off at a certain temperature, so im going to buy one and set it to turn my thermofan on and off and monitor temps with it before and after the grill block
while im at it i will install a vacuum guage aswell, ive read that high vacuum is better for fuel economy is this right?
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
