mount the panel 20 degrees to horizontal, downwards at the back.
run the top of the car back to the panel at 10 to 15 degrees - keep it smooth as you can,.
Then build sides for the panels to fill from the panel down to the hatchback.
Probably does not matter what the sides look like.
