Old 04-01-2012, 03:11 AM   #5644 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Does anyone know what causes a continuous break signal with the serial communications? I'm using realterm, and I'm getting BREAK always set. It says it means "rxd line is broken" I think. But as far as I can tell, the rxd line isn't broken. Are there suggestions on debugging serial communications? I have an oscilloscope I can hook up to rxd to ground, or txd to ground. I never thought to check the serial communications on this board. I verified that it's wired the same as previous boards that actually work.
The RX line on the working one I believe was -6.6v or so. On the nonworking one, it was -13.2v If I remember right. And the working TX was -9.2 and the nonworking was -0.2v. But I can't remember now, I'm too depressed and tired. haha
kits and boards
