Old 04-03-2012, 12:11 AM   #2 (permalink)
jtbo
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
Originally Posted by cbaber View Post
I want to maximize my P&G efficiency by accelerating at around 70% load but I do not have a scangauge to tell me the %load. A vacuum gauge is another (cheaper) way of telling you engine load, so my question is how to convert a simple engine load reading over to the vacuum gauge. I know that when you accelerate vacuum goes to around 0. Is 0 vacuum 100% load? Should I be trying to accelerate at around 0 vacuum to maintain my target load or is it more complicated than that?
0 is 100% and if you would like to use 70% you should use 30% away from zero at least how I understand it.
Amount of throttle is perhaps irrelevant there, just make needle to be at target and adjust throttle so that it stays as it does change with rpm increase.
