Originally Posted by CapriRacer
It would be most interesting to see the results of the (not completed) "air or tire" test on the Ford van!
P.S.
Not so. I've measured it and the correlation isn't direct.
We don't even have to measure... think of the extremes: a tire with 500 psi and a 500 lb load isn't going to have a one square inch contact patch and a tire with 1 psi isn't going to have 500 square inches on the ground. However, there isn't even a small "zone" where that air/weight/area notion works.
