Old 04-03-2012, 12:16 PM   #9 (permalink)
HAHA
Hydroline3 - '09 Mitsubishi L200 Business, Double cab
90 day: 40.86 mpg (US)
Another factor as the voltage drops is that the ECU adjusts the fuel injector timing to compensate. This may affect efficiency and also the calibration for Scangauge or similar systems. I tried to find out once if Scangauge did calculate fuel correctly based on injector timing. I think it may do so but I'm not 100% sure.
Since you are dealing with rather small differences here, you may have to perform a dedicated experiment to quantify these effects. If your instrumentation calculates correctly when the ECU/injectors run on low voltage, it gets easier. Then you only need to find out if the engine works better or worse with normal/low voltage. If there is a degradation, you may be able to find a workaround, eg. extra batteries to keep voltage up.
At least some of your test runs indicate that your engine may degrade with lower voltage.
