No point in bothering with E85 unless you jack up the compression.
The stuff only has two-thirds the heating value of RUG, so your MPG will fall through the floor.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
