Old 04-03-2012, 11:54 PM   #8 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Yeah dude, you are so due for a cleaning. You know how much those injectors cost. This will save you a ton of money. The biggest scam for the electronic unit injectors is that unless you are absolutely horrid with oil and fuel filter changes, and unless there is an engineering defect in the design, THEY DO NOT WEAR OUT. With the HEUI injector, the passages where the oil flows gets carboned up and they have, no pun intended, a stroke. Keep the passages clean, they keep on moving.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
