Originally Posted by i_am_socket
Let's see... Blender + OpenFOAM = software, but time to learn to use and develop models and run tests, understand test results, modify tests to achieve desired data, remodel, retest, etc... unless you're planning on putting your mod into full production
Or doodle and compare and use fuzzy logic until your home-brew 1 off is good enough.
I think it's a bit extreme for all the issues mentioned by ttoyoda. I'd clip it off at a point where it's close enough, but thats me.
Most of that could be achieved by a simple Kamback for the entire rear of the car.. make it out of polycarbonate and it will be totally clear and I can see through it... however it makes a huge hole in the rear of the car for air to spin around and create a draft... however it would be fairly simple to make.. a sheet of it and some bracing etc. and your set..
