Old 05-30-2008, 06:17 PM   #41 (permalink)
adam728
adam728's Avatar
Mazda3 - '08 Mazda 3 S
90 day: 29.65 mpg (US)
DR650SE - '13 Suzuki DR650SE
90 day: 46.16 mpg (US)
Wife's - '12 GMC Terrain SLE-2
Yea, at 8psi a week drop you definitely have a leak. If you have a valve core tool I would try and tighten them. They can come loose. I fought with one on my Jeep for a while before replacing the whole stem. It would hold pressure fine for weeks, then suddenly go flat overnight. Tighten the valve core and repeat the process. Luckily I have an on board compressor! I've also battled the stem that leaks between it and the wheel. Usually blamed on mud/debri getting packing in while off roading. I doubt your Vibe has that issue though
