Are you sure your vac pump won't pull 22inHg? If it will (even if it takes a minute or two) it should work with your system, as long as you have a large enough reservoir. The reservoir should be able to provide three to four brake activations from max vacuum, without the vac pump turning on.
The switch you linked to looks like it will be appropriate.
