Old 04-05-2012, 12:05 PM   #22 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Never remove a battery terminal with the engine running. Unless you want to permanently disable the alternator.
Don't Disconnect the Battery with the Engine Running
I'm pretty sure the low output mode is still charging. I can drive as far as I want without losing any voltage. Honda says 12.5v, but my multimeter tells me it's more like 13v. The easy test to see if it's charging or not is to force the alt in the "low" mode and drive with all the electrical accessories on while watching an accurate multimeter. If the voltage remains steady, the alt is charging. This is what I'm seeing in my '91 Civic.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
