Old 04-06-2012, 12:59 AM   #17 (permalink)
steffen707
Originally Posted by Randy View Post
The stock civic alternator has wire to turn the voltage down to 12v... basically shut off until needed, especially with a AGM battery which has a higher discharge voltage than a flooded.
Unfortunately I don't know which wire, but it goes to the ECU, and is grounded to shut off the alternator. You can just ground it with a switch to force shutoff (the ECU controls it with an open-collector circuit). I did this when I had a '94 civic. You can even monitor if the ECU has shut off the alternator by looking at the voltage: it's about 7 volts normally (you might need a 5k ohm load or so to see this), but about 0 volts when shut off. The ECU-controlled shutoff is fairly rare: it has to be warm, with no lights or fan on.
As we have been discussing, this wire you're talking about is the alternator charging control wire. When grounded it doesn't shut off the alternator entirely. It still is charging, but at a very low rate.
The Following User Says Thank You to steffen707 For This Useful Post:
redpoint5 (10-18-2014)
