Originally Posted by dcb
re: larry, you back in action?
I'm back. I'm going to use my serial freeduino. I tried replacing the ATmega chip from the serial into the USB and it worked fine. So apparently I blew out the USB ATmega. I might try to bootload it to see if anything happens. Either way I've already order a replacement.
