Originally Posted by Frank Lee
There are several threads re: onboard generators... you've been here a while, haven't you seen any of them? As I see it, the bottom line is onboard generating to charge the battery pack is the least fuel efficient way possible to charge that pack AND the least fuel efficient way to get the vehicle down the road. I'm told vehicle-generated electricity is about 5x the cost of household outlet electricity! So if one is to burden their EV with the weight, cost, and complexity of an ICE I strongly think that ICE should power the wheels directly to make the whole mess go down the road, bypassing all the onboard generating/charging inefficiencies.
5x expensive?
I was thinking more on the line of just having the thing there just to maintain battery power level, not to get the car down the road, just as a backup when you can't plug it in.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
