Old 04-06-2012, 08:40 PM   #21 (permalink)
turbothrush
turbothrush's Avatar
2 x wrecked vx - '92 Honda Civic Vx
90 day: 62 mpg (US)
Originally Posted by steffen707 View Post
Yeah just try crusing around at 3500-4000rpm in any gear. I noticed the vacuum on the egr hose occured more often when you accelerated a bit like from 65-70mph in 4th gear and then let off the throttle to enter into lean burn. It would then show up.
Its funny though because in 5th gear doing the same thing it wouldn't do it. Not even once with my car. And I drove around for 30 miles on the highway testing it.
Yep , I found the same thing. Egr gets activated only above 3000 rpm or so and then only for a couple of seconds before you select the next gear, In fact the way I normally drive the car I would hardly ever activate the egr.
I certainly was not expecting this. I always thought a good working erg was one thing needed for good highway fuel mileage in the vx. Seems to be really just for emissions I guess.
One thing I did notice is if while in leanburn cruise you apply some vacuum directly to the egr ,the instant mpg goes up 2 mpg or so and then when you release the vacuum it goes down the same amount . I only tried this a couple of times for a few seconds so it requires further testing on a nice flat road with zero wind . I am thinking somebody must have already tried this idea ...Gotta love the MPGuino for this stuff
