Originally Posted by brucepick
I'll use the car in it's original configuration if I need to do a long road trip, or say I've already driven the limit of what the deep cycle can handle and now I need to run headlights for a half hour or so, which the deep cycle can't do after being mostly depleted. So I'll switch the alt back on and reconnect the 4 pin, and I'll flip a couple other switches to run the entire car off the alt + starter battery. The deep cycle goes "out to lunch" until I'm able to charge it up properly from wall current.
Well I never thought about doing that, but great idea.
That way when the deep cycles are depleated you flip it over to regular starting battery and the alternator doesn't see the huge load of the depleated deep cycles. I got it!
Did you ever find the female side of the alternator plug? I guess I don't know which one is considered the male end and which the female. I was hoping i could find the other end somewhere, but without tearing apart an alternator housing i don't know if this path is possible.
