Old 04-07-2012, 09:46 AM   #5651 (permalink)
electricstorm
Hey Paul!
I received the 500 amp controller two days after you shipped it, however I am just getting around to checking it out. Very well packaged. Thansk for shipping it so fast.
Had a couple of questions. As far as I can tell, the green led was the only thing missing. I am placing an order to mouser for some other items anyway and wanted to ask if the 859-LTL-307G (green LED, mouser part #) is the correct one to use. I can't see having you ship a 20 cent part, it would cost more to ship than the part is worth.
Second question: If I wanted to make all my connections to the control board using connectors (I know you said earlier that soldering the wires to the board is more reliable), what connector (plug, socket and pins) would you use for J1 on the control board? I am not going to use a connector for G1 - G10 or PH 1 and PH2. That might cause some problems.
Thanks again for the kit!!
Jim B.
