Old 04-07-2012, 11:47 AM   #204 (permalink)
oil pan 4
Originally Posted by steffen707 View Post
I thought if you had a deep cycle battery this wouldn't be a problem, because they are designed to be depleated and then recharged?
To a deep cycle battery 50% total discharge is considered depleated.
They seem to say that zero is 10.5volts, 30% left is 11.75, 80% is 12.42.
What that means is there is 0% useable power left at 10.5 volts.
If for some reason you were going to run the battery down to 0 then when you hit 10.5 volts you have used about half the total power inside the battery. But there is no reason to do this.
