Old 04-07-2012, 12:04 PM   #205 (permalink)
steffen707
To a deep cycle battery 50% total discharge is considered depleated.
What that means is there is 0% useable power left at 10.5 volts.
If for some reason you were going to run the battery down to 0 then when you hit 10.5 volts you have used about half the total power inside the battery. But there is no reason to do this.
Okay I thought the definition of depleated was zero power left.
