04-07-2012, 12:50 PM
#210 (permalink)
Originally Posted by steffen707
This mod was described to me as having a cancelling effect if you depleat the battery one day, then use the car's alternator to charge the battery back up the next. The alternator will probably have to work harder on day 2, then it would if you left it on during day 1 and day 2.
The only way this nets you a gain is if you charge from the grid where electricity is cheaper than vehicle generated electricity.
You should only charge from the car if you're in a situation where you don't have enough battery to get home, or if you're running the battery too low and might hurt it.
correct.
