Old 04-07-2012, 05:07 PM   #8 (permalink)
flying kurmaster
unfortunatly the truck is on a different continent, you can see the kurbmaster in the "exterior sunvisor" thread I started a while back, the tire would not likely go above the hood as Franks says his does, but the more I think about it, if there is no areo advantages putting it up front I think I will concentrate on designing a mount and installing it on the back as there is room there and it may be a better choice for looks. I can block the grill with something else easily enough. I was mostly wondering if there was any advantages to having it upfront, it seems that is not the case and possibly some disadvanteges. 'cheers fk
