Old 04-07-2012, 06:31 PM   #14 (permalink)
Tesla
The Truck - '02 Nissan GU Patrol ST
I was thinking about this rounding vs sharp cutoff, and did some research, and yet again found myself reading about projectiles, specifically RBT's (rebated boat tail, bullets). The bullet is rebated, just before the boat tail, this causes the propulsion gasses to create a better cushion behind the bullet to push it out faster with less wear of the barrel.
Anyway it got me thinking about what drmiller100 said about the air wrapping around the vehicle, my consideration was primarily for the junction between the boattail and vehicle, just like the RBT. Rather than having to merge the tail with the body panels, which gives the boat tail a leading edge into the airflow, what if we actually mount it just attatched to the rear and deliberately set in from the body by say 1-2", give or take about half way around the body panel curve, then start boat tail from there.
This would make design and attachment easier and may even allow for a further reduction in the boat tail rear area. I imagine at the rebate as the air begins to wrap around hard it will form a small vortex in the rebate, but with an angled boat tail reattachment may be possible.
Possible or Crazy?
