Old 04-07-2012, 09:16 PM   #24 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by JoJotheTireMan View Post
That is exactly how mine is setup, hooked to manifold vacuum. Low vacuum equals CAI and high vacuum equals WAI/HAI. A3 (1993-1999) VW 2.0L air box has dual inlets and a vacuum controlled flapper to switch back and forth.
My 91 Jetta had one of those, but the cold air intake was only 1 inch diameter. I tore that whole thing out and made it a 4 inch diameter feed directly behind the headlight and I actually gained 2 mpg. But it didn't run so well in the winter; stumbled routinely...like I had water in the gas.
[edit] maybe I should have made the flapper bigger instead...
