Old 04-08-2012, 06:07 AM   #57 (permalink)
jmcc
It will depend on the vehicle and technology available, but EGR is generally switched off at cold ambient conditions because of the increased likelihood of misfire. So, my thought (not tested I should add) would be to trick the ECU into thinking its operating at low ambient temperature. Since the IATS generally works on a resistance basis, it should be possible to adjust this feedback.
I don't have more info than that at the moment, but if you have a scan tool and can see both EGR and IAT, you should be able to find out at what temperature this happens and using a multimeter measure the sensor response to temperature as a resistance. If you can then supply an adjustment to this resistance, making the engine think it's at cold ambient, then it will turn off EGR and I expect, advance the timing.
As I say, not tried it but think this may be easier than sending dummy MAF signals.
