Old 04-08-2012, 10:52 AM   #4 (permalink)
drmiller100
Originally Posted by deathtrain View Post
For the people that have fuel cut off switches. Do you engine break when stopping? Here is my plan in my head after i get the fuel and alt switches put in. I would put clutch in, hit the fuel cut off to kill the engine and EOC. Then get closer to my stopping point back into gear. Turn on the Alt again and then hold my fuel cut off button. In my head this will Engine break without starting it back up and give me some regen. then just let go of the button to fire it back off.
please discuss pro's and cons.
sounds pretty complicated.
Tap into the brake switch. When the brakes are on, power to the ecu is off and power to the alternator is on.
optionally, put a microswitch on the throttle - if at idle, engine off and alternator on. then when you are coasting up to a stop sign the injectors will be off but the alternator will be charging.
alternators are often 100 amp now. a little bit of 100 amp charging will really extend your range on your 12 volt battery.
