Thread: BSFC Mapping
Old 04-08-2012, 12:05 PM   #10 (permalink)
jmcc
Originally Posted by drmiller100 View Post
what you could get is instantaneous mpg.
which is meaningful.
For back to back under controlled conditions maybe. Question was about generating a BSFC map and the errors in the fuel calculation in the ECU make this too inaccurate to be useable (in my opinion).
Reason for inaccuracy: fuel flow is calculated as a function of rail pressure and injection duration for a nominal injector. Injector flow particularly will vary, and needle lift vs electrical pulse will also be inconsistent.
