I think a big issue is that you deactivate cylinders on the same throw (for a 4cylinder, either the middle pair or the end pair) you can't split half way as you would get uneven firing. If you rearranged so you had it splittable in the middle you'd have terrible dynamic balance when running 4 cylinders, and even worse once split.
Reason: Typo
