Old 04-09-2012, 04:26 PM   #6 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by goshockers View Post
1) Fuel up at dawn/dusk/night when it's cool to minimize ozone release and fuel evaporation.
Tanks are usually underground here, and as such should only have small temperature fluctuations during a day.
Delivery systems are temperature-compensated.
2) Don't fuel up if you see a refueling truck refilling the storage tanks as sediment and such gets churned up during this process and you can get "dirtier" tanks of gas.
Fuel is filtered.
What doesn't get filtered out is water though.
Pumping in fresh fuel can get water in the fuel station's tank stirred up - water which shouldn't be there in any serious quantity in the first place !
Over here, problems with excessive water in fuel tanks are few and far between, but they do happen (mostly with non-branded fuel stations) and will kill a diesel pump over time - and your mileage.
3) Always use the same pump at the same gas station and fill in the exact same way for greatest accuracy on manual MPG calculations.
This is a trick to get more consistent fill-ups, by eliminating differences between fuel stations.
The ground at the fuel station is not always completely flat.
You avoid differences in fuel delivery systems, in shut-off function, nozzle length, ...
4) Use the lowest (slowest) notch on the handle when allowing the pump to auto-fill as running the pump wide-open allows some fuel to "vaporize" (or otherwise show as being pumped into your tank but never reaching it).
I lock it fully open , and let it shut off automatically.
Pumping gas slowly also has a downside, as it means the tank is open to the atmosphere for a longer period.
There will be some evaporation during fueling either way, but with tight fitting fuel nozzles with gas fume returns, that eliminates most of the issue.
Diesel hardly foams anymore these days.
It used to foam a lot more, which could throw off the consistency when filling up.
5) Never top off your tank after the pump shuts itself off as most of that extra gas will just evaporate.
Modern cars have systems that trap and condense the evaporating gas and keep it from going into the atmosphere.
Topping off can fill that system, and leave less space for heat expansion.
Don't top off if you're not going to drive a considerable distance right after fueling - and create some space in the process.
One thing I am wondering about: is the auto-shutoff fairly consistent?
It is for me.
It's just a matter of shoving the nozzle into the tank consistently.
