Old 04-10-2012, 12:35 AM   #16 (permalink)
Thymeclock
Originally Posted by mcrews View Post
and to the other poster......have you read the numerous successfull coroplast panel threads?
Does that mean it is the only material that will work? Does that mean it is the easiest or best solution, because it is the one most often used? BTW, thin sheet aluminum is thinner, lighter and more durable than plastic, regardless of what you say.
metal/aluminuum is NOT the answer.
If you haven't tried it, how would you know? Or are you just being contentious (as usual) and prejudiced, in the truest meaning of the word?
you need big washers or actual strips of steel or alluminuun to put up against the plastic.
Oh, really? Thank you for proving my point. Now please tell us how adding "strips of steel" will be lighter and more advantageous than using sheet aluminum to begin with.
The Following User Says Thank You to Thymeclock For This Useful Post:
Sven7 (04-11-2012)
