Old 04-10-2012, 12:19 PM   #1 (permalink)
brucey
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Cavalier Owners: Is your dash cracked?
Because well.... mine is.
At first I thought just that front piece had cracked under extreme heat, seeing as the car has spent 12 years in Florida. And that I could simply replace that strip. Not so! I have to replace the entirety of the dash, including removing the steering wheel in order to change it. (Thanks, Chevy!) As I was finding out how to remove the dash, I realized the entirety of the dash is cracked, everywhere, and that's just the parts you can see that is cracked.
Looking for a good condition dash that isn't broken into little pieces is proving more difficult than I thought it would be. Junkyards have none, and any cavaliers that are getting parted out also have cracks on that piece (and I assume everywhere else).
So basically, yeah, where are the Cavalier fans here and what have you done about your dash looking like garbage?
Name:	2012-04-10 12.09.13.jpg
