Old 04-10-2012, 03:01 PM   #38 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by yostumpy View Post
could this work on a turbo deisel? with an electric fuel cut off solonoid on , say , the two inner injector pipes. Which would be the best 2, inner or outer cut off. How would the turbo react to only working on 2 cylinders.Would a fuel cut off solonoid work on the high pressure side of a Bosch mech injector pump. The engine is 2500cc, so I wonder if a landrover would drive (on highway) on 1250cc without overheating?
Go common rail, and then turning off the fuel is easy--just turn off the injector. As far as the turbo goes, I think I'd be okay. I'm not sure about the overheating concern--you'd be putting less heat into the coolant with half the cylinders.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
