Old 05-31-2008, 12:56 PM   #28 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by i_am_socket View Post
Let's see... Blender + OpenFOAM = software, but time to learn to use and develop models and run tests, understand test results, modify tests to achieve desired data, remodel, retest, etc... unless you're planning on putting your mod into full production
Or doodle and compare and use fuzzy logic until your home-brew 1 off is good enough.
I think it's a bit extreme for all the issues mentioned by ttoyoda. I'd clip it off at a point where it's close enough, but thats me.
I'm not trying to divert this thread , but I looked at OPENFOAM, and I think it is just for Linux. Also, it apparently takes a knowledge of math to use it - so that leaves me out.
I have a model of this very car. ( an early model CRX )
I'm not sure if it is in a correct format for me to use though ( it is a .DWG )
I was also modeling a VW Jetta for use in some CFD testing.
Perhaps I could post the model of the CRX here, and one of you guys with the brains could figure out OPENFOAM.
