why don't you just try a new main relay?
my kid had a 91 crx we just sold.. it had a similar problem. If you used a test light to test the wires, one of them glowed dimly, and then the relay worked correctly. swapping the main relay it still did the same thing.
I got pissed, and added a ground wire to that terminal in addition to whatever else it went to.
worked perfect ever since.
