Old 04-11-2012, 12:40 PM   #114 (permalink)
steffen707
Originally Posted by brucepick View Post
I'm trying to avoid that degree of home-brew. I found a nice 14V AGM battery but found only one on the market. XS Power D1400. Rated 50 AH. Cost with dedicated charger would be about the same as the ~12V Odyssey I described above. I hope to test for lean burn at 12V this week or maybe next weekend. Hard to get time for real world stuff; much easier to type on a keyboard :-)
I know you went with a different battery, but do you know if their 50AH rating is for 1amp draw for 50 hours? Do they all just assume its a 1amp draw? This is kinda a sweet setup as you don't have to use a DC-DC converter which would have an efficiency loss every time you use it.
I also am concerned about this charger for your pack, http://www.batteryspace.com/Smart-Ch...de-use-CE.aspx doesn't mention if its a 3 stage charger or not. It says "smart" charger, but what does that really mean?
