Over on dieselplace there is something called "dinosaur fan mod", where you put a radiator fan from a military hummer into a chevy 6.2L or 6.5T diesel truck.
The fan was tested and reportedly to used over 40 horse power at max engine speed.
Now the max speed on those engines is between 3600 and 4400 RPMs. A race motor can turn well over 8,000RPM no problem. To double speed on something like a fan you have to 8x horse power as long as the blades don't stall.
Just driving down the road at normal engine speed a regular fan could be using 5hp or more if the fan is engauged.
